The provided CA certificate is not valid.
Provide a valid Trusted-ca/OCSP signature-ca certificate which meets the following: - certificate must be in PEM format - certificate must be less than 8KB - key usage must be available - key cert sign must be present in key usage - basic constraints must be available - notBefore and notAfter options must be valid
Warning
The provided CA certificate is not valid. Reason: %reason%
| Name | Type |
| reason | String |
